Question about the router on the Summa F series
bigben
Not a newbie
I'm considering the Summa F1612 to mainly use it to cut rolled stock but also rigid material that will use a knife. I will probably add the router in the future. The router will be mostly use to cut acrylic and mdf. My rep told me it won't cut aluminum. Is it true? If not, how thick I could go. There is also two type of router but not sure I understand the variance.
So basically, I need overall feedback on the machine and more details about the router part.
Thanks.
brdesign
The router for the F1612 works great on ACM, but I wouldn't recommend it for any aluminum thicker than the face of ACM. You might get by with aluminum using lots of very shallow passes, but the machine just is not designed for routing metals. It's a great machine for almost everything else.
White Haus
Not a Newbie
We have the basic/Kress router on our F1612 and I wouldn't recommend it for cutting aluminum. Pretty sure you need some sort of cooling/misting feature on a dedicated CNC to properly cut aluminum. I've tried, and have broken bits and wasted a few hours. ACM will cut nicely when you get the right bits, and settings going.
The difference between the router options is power/capability and about $15k CDN if I remember correctly.
MDF will cut beautifully on the F1612 with the basic router but I'd request samples of acrylic to make sure you're happy with the finish. I haven't gotten acrylic cutting with perfect edges dialed in yet and have done quite a bit of testing.
PHILJOHNSON
Sales Manager
Good afternoon,
I wanted to follow up on what other members already said and recommend not cutting aluminum with either router system on the F1612. ACM, acrylic, PVC, wood, etc. are all no problem but because there is no bit cooling the bits get too hot when routing aluminum and the material actually starts to melt and stick to the bit. I have tried routing several different types of aluminum, with quite a few different bit types, and none worked well.
I have attached a router comparison document to this message as well and it talks about the differences between the two router systems. Feel free to PM me here on the site or send me an email if you have any other questions.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext. 112
philj@airmark.com
  • SUMMA ROUTER COMPARISON.pdf
bigben
Not a newbie
Thanks all for the comments/feedback. I'm in Canada and the price variance between the two router option is a bit under 18k$ (8694$ vs 26647$). PHILJOHNSON Thanks for the document. I understand the benefits and variants but does the difference justify the 18k$ différence?
I also have a small concern about board problem I saw in another post. From what I understand, the ''new generation'' does not have this problem. I'm a small shop and this cutter is a very big jump for me. Having this machine down for over a month could be a big problem financially.
White Haus
Not a Newbie
We learned about the board issue from other members here and I had to call our dealer (Grimco) and tell them about it. We deactivated F-Performance (one of the common causes of the board failures) and then were told to re-activate it while we were still under warranty - haven't had any issues yet. (Knock on wood)
We just had it go down for the first time in over a year, the vacuum selector is all messed up so we're basically down and waiting for parts now.
Assuming you're going with Grimco or ND, how close is the nearest tech to you? I would make sure they will fly someone out to service your machine if it does go down. We're also a smaller shop and this thing going down is not good, have 3 printers feeding it work and can quickly create a backlog.
ProColorGraphics
I would wait on the router as they have a new standard router coming out that will be a lot nicer and more powerful. Just not sure when it will be available yet.
bigben
Not a newbie
I'm getting it from ND. Customer service from Grimco is horrible here. I assume their tech is located in Toronto, but I will check this out. I assume if I buy a new machine, I will have the new board version. I hope so.
Interesting. I assume it will fit on their current table? It would be a shame if they change the whole thing for the router. I'm in no rush for the router part. I can wait.
ProColorGraphics
I am still waiting on details for that. Mine is 3+ years old, so I am hoping it will work with older models.
bigben
Not a newbie
FYI, here is an answer I've got from my dealer. He forwarded it to me.
About 6 months ago we did release a revised carriage board which is included on all new machines since 6 months ago.
We are planning to release an upgraded version of our standard Kress router in the future but the release date in North America is still undetermined.
The only difference in the upgraded router is the motor. Instead of a 1Kw motor it will be a 1.4Kw motor, no other change. (price in Canada will be 10k$ instead of 8k$)
bigben
Not a newbie
So... There's a new contender in the lot. The Colex SXC1717. The bed is a bit bigger than the Summa F1612, there is more router options and price seems similar. I've red on another post that software wise the summa is ''better'' than colex. Again, I've never had a flatbed cutter, so I'm not even sure what questions to ask. If we put the router part aside, what is the pros and cons of each machine? And in the router departement, what is the variant between the two?
ProColorGraphics
Have you checked out the Apex lineup from CWT?
ProColorGraphics
The dealer that sell colex also sell cwt application table. I assume he would have proposed it to me. Is there particular benefits on the apex?
They seem like a decent machine to me from what I have looked at them. Just helping you explore all of your options. ;)
kosh_al
The standard router and the HF router are definitely not the same. The HF router has a balanced pneumatic collet and pneumatic air cooling of the collet and motor, allowing for higher RPMs and more versatility and finer finishes in materials that can be cut (see Phils post above with brochure on the differences in the two router options).
Our HF router cuts dibond at full speed (4in sec) without issue. We have cut acryllic with a nice smooth edge, 1' gatorboard, 3/4" Sintra. We are a small sign shop and the Summa with the HF router has eliminated our need to outsurce router cuts. The final thing was the 1 inch Gatorboard, once we successfully routed that, we no longer need to pay someone else to do our routing. As far as vinyl and foamcore cutting, the Summa F1612 is a dream!! For drag knife type vinyl kiss cutting, the standard plotters are faster though, but most cutting we now do on the Summa. It has really helped with filling in the gaps where the employee issues cause reprints for recuts, etc. It has made us more accurate and eliminated a lot of the human error element which costs us money in rework/reprint. For our sign shop, the Summa F1612 has been a game changer and stress reducer!
kosh_al
Good afternoon,
Best regards,
Phil Johnson
Airmark Corporation
philj@airmark.com
Phil, have you tried routing the .040 aluminum with any of the coated bits? I've seem some coated bits advertised as being able to cut aluminum without active cooling.
balstestrat
Problem Solver
It's years old stuff but he is talking about the two different standard routers, not HF.
ProColorGraphics
I have the 1400w standard router in mine. I actually just ran some .020 aluminum with zero issues. So I have no doubt I could do .040 or thicker, would just take more passes.
Although, I have setup with my machine with an airline so that there is a blast of air blowing at the tip of the bit to keep the chips cleared out and the bit cool. ;)
kosh_al
what bit did you use?, what movement speed and spindle speed?
