Random print with Roland
designtcd
Hello everyone, I'm having problems with printing on my Roland SP-540i, I replaced the cables from the head (short), it only happens on yellow. Any suggestions on what to do next?
Sometimes it works without any problems, and sometimes it's impossible to print anything without yellow lines
Test print 99%
This looks very much like what we call block printing that has happened in the VS models. I have never seen it happen in any other model. It is generally related to the long cables from the print carriage board back to the main board.
However, what you might want to try first is swapping the heads and see if the problem follows the head.
Being it is a SP and an old printer it probably has many hours on it. My gut feeling is it will end up being the long cables.
  • Agree
Reactions: 1 users
damonCA21
If it isnt the cables then you need to check the head transistors. The control when the head turns on and off, and if it gets them at the wrong time it can cause thise
