real estate signs
chopper
Hi,
what do you all get for a two sided real estate sign 2' x3' quanity of 10
two 3/8" holes punched in the top, 5,-3/8" holes in the bottom,
with a 3 color layout with logo one of the colors is reflective,
all cut vinyl ( dam these real estate guys are cheap!!!)
on aluminum blanks.040,
thanks...//chopper
mystysue
I would add a bit because of using reflective.. but we get 65.oo to 75.00 a sign for the double sided 18" x 24" size, if done in cut vinyl.
imaSIGNr
real estate guys are cheap cause they want to compare a single custom sign to one that they get screen printed by the hundreds or thousands and pay only $2-$3 dollars for. Probably want you to throw in a bracket too......See what kind of deal they'll give you on a house ?
(2) sided 2 x3, 3 color w/ refl.$90-$100
You've got as much or morre into it as you would lettering (2) vehicle doors. $100 is cheap, but they won't see it that way....
10 signs....no less than $75-$80
That’s a tough one. I would talk them into more signs and screen them and make more money than doing all that layering, cutting, weeding applying and other time consuming work.
Doing ‘em all in vinyl, they’re worth about $100 a piece plus you’re reflective cost. $1,100 or so seems like more than any real estate customer will spend for a few signs, but screening 20 signs for about $650 total is more up their alley.
Good Luck..........
MobileImpact
24x36 2 sided with reflective. About $110 ea. Depends on how much is reflective.
What about stands or frames?
Why 5 holes across the bottom? we do tons of these and have never put 5 holes across the bottom?
Kevin
chopper
good point gino told them to have them screened and they didnt want to do that, why I dont know....also it is kinda hard to screen print reflective...
thanks. //chopper
chopper
I dont know why the five holes some kinda rider I guess,
but I have adopted the marines moto on this..
"its not my place to know why just to do or die"
they allready have the posts
//chopper
You print everything but the reflective... that you'd have to still do by die cutting.
Here’s where you have to ‘upsell’ another product. You let the customer know with screen printing:
  • How much longer they’ll last
  • Your cost is less, thus making their cost less
  • They will get twice the number of sign for almost half the outlay.
  • Turnaround is much faster
  • Better all-around product
  • Last….. you highly recommend it…. but if they insist on paying more, you’ll gladly do it. You’re just looking out for their best interests. Say this part very earnestly.:rolleyes:
Try it. Call them back and tell them you’ve been thinking about this and you need to bring up these points to them so they’re totally aware of all of their possibilities.
One question chopper…. Can you screen print ?? If not, my pricing is a little off if you need to farm that portion out, but still all-in-all, they should save money.
chopper
thanks for the help and gino no I do not screen print, thought about it but
I have enough on my plate now //chopper
