I've done several pen plots on mylar for my day-job. I first charged them $50 per plot and they varied in size, but were approx. 2' x 4' and upwards of 6'. They also provided the mylar. I did one lot for $37.50 for each plot. They supplied vector files, but the conversion from the native format to what I use caused all the lines to be broken and in small segments. So, I had to do cleanup on all of them as well or the plotter would take forever to finish trying to draw one segment, then another, then another instead of one continuous motion for a line.
At any rate, I'd think charging your everyday shop rate is a fair method plus any materials and markup - just like if you were making vinyl graphics.
One thing you MUST do if they need to be very accurate is to calibrate your plotter. Mine were being used as flat patterns for aircraft parts and needed to be highly accurate (within .01" or better). What I found odd was I had to recalibrate the plotter several times over the course of doing these over multiple days (while wasting a lot of mylar). I called Summa thinking the plotter resets it's internal calibration after turning it off or something, but they said it shouldn't. I have since updated the firmware and it seems to be better now for some reason.
