Click to Support Signs101 ...
I though about using my Mutoh then laminating them or subbing them out to a screen printer. However the price I got back from the screen printer was $5.00ea @ 200 and $3.00ea @ 500
I figure I can do them for $2.00-$3.00ea @ 500 but I don't want to underbid it eather. because the 3M reflective vinyl is not cheap.
There is a "temporary" 3M reflective material in the IJ (inkjet) series & it is quite a bit less expensive. The adhesive is supposed to be "short term" but for a lot of jobs that could be acceptable. Your decal job sounds like one that may qualify for that. I've done 100 real estate signs & not had any problems.
I have to ask, why would you want to inkjet print and laminate? And, is that size carved in stone?
I can get them screen printed on reflective for around 55¢ each and I would retail them for $1.11
Yes the size is set in stone! and these are 2 color with a solid color bleed off and the black text is like 1-500. so each one is different.
they need to be laminated because the decals I'm replacing are laminated. If I print them on the mutoh the ink will scratch off so I must laminate them.
Checkers, I plan on using 3M white reflective vinyl because that's what they have now and also I like using the 3M.
I will need at least 10y roll to cover my job and that is $125.00 just for the vinyl. At 500 asuming I use 22ft is aprox .30¢ea just for the vinyl.
So your saying some one would print and trim these for .20¢ea or a mer $100!
I can't go that low just because it would not be worth my time to deal with the job...
I need at lease $250.00 just to deal with it if I don't touch it or $500+materals if I manufacture them.
The place that wants these is not really price shopping and I have about a 99% chance of getting the job as long as some one on the board of directors does not have a buddy who will do these for nothing. I just want to shoot them a fair price and make some money too.
Since you're saying the the specs are carved in stone, I would definitely note on the quote that you are producing custom decals to their specifications.
Since your custom products can not be compared to an "off the shelf" item that is ordered from a catalog and produced in bulk, your price will be higher.
And just for comparison, check out this... http://www.seton.com/seton/catalog/...decals/20/10/~0/false/0/~0/0.html?sblid=37345 500 - 4.5" x 2.5" reflective decals would retail for $1.65 each.
My cost of 55¢ each was a smaller decal using a standard design template that would be provided by my screen printer.
