reflective tape
B-Man
looking for a white reflective vinyl for numbers to stick to some plastic squares can anyone recommend a reasonable priced vinyl?
I use oracal 551 for normal stuff. I'm thinking Oralite 5500 as it seems to be the only oralite that doesn't say "The material is strictly intended for adhesion onto even metallic surfaces, such as aluminium and galvanised steel" and is the lowest price for oralite
Albert Cyrus
If you prefer Orafol products, have you looked at the Oralite 5400? It's less durable than the 5500 but usually a bit cheaper. Plus it's solvent printable. I don't know what the specs say, but it works great on non-metal surfaces.
rjssigns
Could check into Nikkalite reflective. Haven't used it in a long while but never had a call back.
B-Man
Just have an account with orafol more than prefer their products.
I would have thought most should stick to non metallic surfaces but they all say even metallic surfaces.
Will check out Nikkalite
Thanks all.
