I don't remember exactly what C36 stands for on the CJV200, but when marks never read, it's almost always one of a handful of setup things rather than a broken sensor. Since you're running FineCut and RasterLink, I'd go through these:
- Make the marks with FineCut's own register mark tool, not drawn by hand in Corel, and keep the mark type and size the same as what's set on the machine. If FineCut makes 10 mm marks and the cutter expects a different size or shape, it won't find them.
- Leave some clear space between the marks and the artwork. If the image runs right up to the marks, the sensor can pick up the print instead.
- Before you start detection, move the head so the light pointer sits a little inside the first mark (on most setups that's the bottom-left one). If it starts too far away it gives up.
- Media matters a lot. Glossy or laminated vinyl reflects the sensor light and causes misses. Try it on plain white matte vinyl first, and let the print dry so the marks are solid black, not still wet.
- Check that the media is loaded straight and lying flat. A curled edge or a skewed roll can push the second and third marks out of range.
If it reads fine on plain white matte, you know it's the media or a setting. What vinyl are you printing on?
