Remove old vinyl decals
Nitromax
Hi, is there a way to remove old vinyl decals without damaging the paint?
ProntoPrinter
You can buy plastic razor blades that you can use to lift edges and then peel. I’ve used my fingernails but they get sore when you use them a lot. A heat gun or let it sit in the sun for a couple of hours will make it go faster.
Reactions: 2 users
ProSignTN
Lil chizeler used to scrap fish tanks works better than plastic razor blades. I keep at least one sharp thumbnail for peeling vinyl, two if it's a big job. Also, removing old vinyl is the one thing I will not quote. Time and Material only.
Nitromax
I think this job would take about 2 hours, plus another hour for the round trip. I quoted the client $180 CAD for the job, but he thinks it's too expensive. I guess he can take care of it himself.
Reactions: 1 users
i was just thinking that i have difficulty sourcing replacement fingernails...
  • Hilarious!
Reactions: 1 users
visual800
we use razor blades and dull them against glass, make sure the ends of the blades are real dull and go at it, clean up with rapid remover
DL Signs
Never go against the family
One thing to note is that truck bodies are aluminum, watch how much heat you throw at it so you don't warp any of the panels.
Reactions: 1 users
Boudica
plastic razor blades - heat gun if necessary. follow up with adhesive remover if there is any left (ETA, I thought I posted this on Friday)
guillermo
I really use a metal blade, the ones that go in a scraper, but what I do is round the corners, with that I remove the vinyl from cars, yes, from cars, if you lay them flat and move them in an angle, from bottom to up or from right to left, about 1/16" at at time, you get the adhesive vinyl removed with little or not glue residue.
Boudica
i use those all the time
it makes my wife's non stick pans last a lot longer, as well
there is one by every sink in the house
I have something that looks like lil' Chizlers, but they are made for pans and way more durable. A rubber one for the non-stick ware, and a plastic one for cast iron and other pans.
Actually, a lil' Chizler would work well for the OP's removal as well as the plastic razor blade.
