Reusable Decals
SwinkCreative
Graphic Designer
I'm looking for someone who can print decals for a dealership that says "For Sale" The artwork for the decals will be supplied to you in a bubble/oval about 24" long - all you need to do is print them.
Specs of the project:
Cling or Vinyl that adheres to the inside of the truck's window.
Re-positional and reusable up to 2-3 times
Thank you,
Lindsey
ams
Thank you,
Lindsey
Does it have to be printed reverse on the adhesion side?
SignMeUpGraphics
Super Active Member
Yupo is optically clear, so you still print first surface, mirror the design then apply inside.
Unfortunately I don't know anyone in the US that can print onto it. We have a near full roll on the shelf at the moment but are quite a distance away.
ams
Preferably - These go on the windows of Semi Trucks that are for sale so they need to be inside if possible otherwise the guys will need to get a ladder if installed on the outside.
That will collect a ton of dust on it or be very expensive to produce by putting a roll of adhesive across the printed side.
ams
In order to do a reverse print, the only other possible way is to use clear decals, but I don't know of any that are clear and reusable.
If you use the micro suction reusable ones, you would have to print on the suction side to be able to put it inside the vehicle facing out.
