Review of the Roland LG-640
jlgb
According to Roland themselves the "running costs" or the maintenance consumption per day of the Roland LG-640 is 5.7 to 7.6 times higher compared to the Roland MG-640. See below.
depps74
Review of the Roland LG-640 (2023-Nov) Do NOT buy!
As little info is available online regarding the Roland LG-640 (LG-540 & LG300) I decided to write a little review of my experience with the new Roland LG-640 during the last 4 to 5 weeks.
TL;DR. Do NOT buy. Reasoning.
  • Excess amount of ink wastage in drainage bottle. Over € 9.200 euro (> US$ 10.000) a year.
  • The amount of ink you put on the media cannot be controlled/changed.
  • Speed is significantly below the 12 year old XR-640.
  • No deep CMYK black, it is simply a dark brown!
  • The horrible smell.
Our background.
We have been printing with Roland printer for about 25 to 30 years (at the moment a XR-640 and a VS-540 with eco-sol max 3 L ). And we have also been using Roland cutters, up to and including the Roland CM-500. After which we mainly started using Summa’s Tangential cutters.
If you have any questions. Let me know.
1. Running cost are absurd high.
The amount of ink the printer throws away in the drain-bottle is simply unacceptable.
We printed for 7 days straight, after receiving the printer, to get a good feel of the machine. And boy was it disappointing. According to Roland 16 meter a day (52 feet) was printed during this time. Of those 16 meters, I would say about 5 to 10 m2 was completely covered with ink. After these 7 days, about 40 printing hours I would say, the printer had dumped more-or-less exactly 1,4 litres (1400ml) of ink into the drain bottle (200ml a day). At € 130 euro for a 750ml cassette this equals to about € 242 euro (1,4*130/0,750) (1 Euro is 1,09 US Dollar).
The printer also dumps about 30 ml a day in the drain bottle, if you do not use the machine. Based on 250 working days this will cost you 250*200ml + 115*30ml = 53,45 L a year.
Our existing machines do not even dump 6L into their drain bottles combined, a year.
This will cost you 53,45L * €130/0,750ml = € 9.264 every year if you use the machine for about 5 hours a day (production speed of this machine is about 3 meter an hour effectively, more on this later).
The excessive ink consumption completely defeats the purpose of switching from eco-sol to UV!!!
2. No print profile control.
The printer comes with 6 generic print profiles. Of which 5 are basically the same, with little to no difference. Whereas with eco-sol printers you can very the amount of ink you put on the media to a very large degree, this is simply not possible for the Roland LG-640. It will put very little ink on the media (and an excessive amount in the drain bottle). Thus, making the machine (almost) completely useless for printing on transparent/translucent media.
In addition, you will be unable to match (extremely limited in matching) a eco-sol gloss print with a UV mat print (on transparent/translucent media).
The sixed print profile is backlit which a basically just overprint. This slows the machine down to under 2 meters a hour.
3. Production speed of the Roland LG-640 printer.
When in quality mode “General Sign Production” 900x720dpi the print speed of the LG-640 is more or less comparable to the XR-640 print speed of 720x720dpi. About 6000x1300mm an hour.
However, the production speed of the printer is way below 6 meters a hour. Because of the following two reasons, the production speed of the Roland LG-640 is significant below expectations.
One. Due to WAY too many maintenance, cleaning and ink cycles. The ink usage of the machine is simply unacceptable (nov-2023). For small print jobs, the machine needs an excessive amount of time doing maintenance, cleaning and ink cycles compared to doing very little printing. Especially if you do a couple of small prints with white on top or under a colour layer. The machines will spend more time doing ink/maintenance/cleaning cycles than printing!
It will continuously do cycles before, during!?! and after prints.
Every 6 hours the printer runs a maintenance cycle, when off. If you turn the printer on, just 5 minutes after it has run such a cycle, it will again run a maintenance cycle!?! Crazy! I hope they can/will fix this in a firmware update.
It will be about 8 minutes before you can use the printer when you turn it on.
Two. Too little ink on the media. Thus needing to use overprint, way more compared to a eco-sol printer, to get an acceptable end result. Overprint reduces the speed of the print speed to less than 2 meters an hour.
Overall production speed is significantly lower compared to our Roland XR-640. Disappointing to say the least, as the XR-640 was introduced by Roland over 11 years ago in 2012 in the EU.
4. Colours. No black for you!
Printing CMYK black in not a deep black compared to the eco-sol CMYK black. It is almost a dark brown. An eco-sol CMYK black will fit almost perfectly besides a black coloured vinyl but black printed on the Roland LG-640 sticks out as not being black!
Solution? None! Switching to a RGB black gives better blacks (a darker black) on the LG-640, but this is not a solution. The printer simply uses too little black ink to make a nice black on white vinyl. Using a different print mode/quality does not change this. Only using overprint solves this, but this is unacceptable.
Conclusion. So printing a nice CMYK black with the Roland LG-640 is not really possible, at this moment.
The orange and red cassettes create great red colours, especially compared to the poor red colours of the eco-sol max 3 ink.
5. The smell!
The machine sure smells. Much much more and worse compared to an eco-solvent machine. I would strongly advise putting it in a separate room.
Banding.
Machine was installed by a Roland dealer. It uses more or less the same calibration as the eco-sol machines. Banding was, and is still, present from the beginning in most prints, especially on transparent/translucent media.
Print Quality.
Very nice mat finished end result, very nice colours, just beautiful.
3 layer prints (colour – white - colour).
Nice for small stickers, but not really useable for cut-to-shape signage. Our application tape does not stick to this type of 3-layer print work. We use R-tape high tack 4075. You will have to laminate the film/designs first for the application tape will stick to it (which I would not advise given the very ruff/bumpy surface of a 2 and 3 layer print).
It is, at the moment, not possible to print 3 layers in one go. You print, return printer to origin when finished and you print again on top. Colour – white in the first pass and subsequently colour in the second pass.
Regressions.
  • Cut force cannot be changed during print or cut. WTF??? This is immensely stupid. It is not present on the main page of the machine. It should be present on the main menu and you should be able to change the cut force at any one time.
  • Cut sheet now requires 2 button presses instead of 1. Like many other actions now require way too many navigations/button presses. Again slowing everything down.
Display.
Does not show force of the blade or have an indicator for the level of the cleaning cassette. You will be pressing a lot more buttons, compared to a XR.
Pickup unit.
You now have 2 different ways to roll the material onto the cardboard tube/core. VERY handy. The new method keeps the material coming out of the printer lose, as it does not put tension on it. VERY handy.
Energy consumption of the Roland LG-640 printer.
Below expectations, in a good way. Specs say 800 watts. But real world usage of energy is much lower. 180 to 220 watts when printing, around 75 to 80 watts when not printing and about 45 watts with secondary power off.
Thus, energy consumption during printing is much lower compared to the XR-640 with the additional front heater. With secondary power off, the energy consumption of both printers is about the same.
The BOFA fume extractor consumes about an additional 80-110 watts when in use. I measured around 108 watts on average during the day.
Cutting.
Unlike solvent prints the printed part with UV are thicker compared to the unprinted parts. Whereas with eco-sol you use the same cut force for printed and unprinted part. You will need more force for the printed parts compared to the unprinted parts. Especially for 2 and 3 layer prints. Thus, media with thin backing can/will give problems.
Other issues of the Roland LG-640 printer.
  • The lip on the left of the metal UV guard on the back bends VERY easily, thus continuously dropping the guard/lit on your “fingers.” Very annoying.
  • Heavy roll carriers in the middle of the machines, crease the vinyl, so (re)move them!
    • Solution. Move them to the sides and flip them over.
  • Media clamps accumulate a lot of adhesive at the bottom. We “never” had to clean the media clamps of the XR-640 in 7 years. We needed to clean the media clamps of the LG-640 within a week (a couple of days). Similarly they are collecting UV ink on top.
    • Solution. Do not use the media clamps on vinyl (cheap Chinese stuff) that has shrunk on the backing exposing a little adhesive. Media will stick to the clamps and printing and/or cutting will cause media errors.
    • It looks like the new media-clamps scrape more onto/into the material and thus accumulate adhesive on their bottom.
    • They are black and very hard to see.
      • Roland please make them Roland blue, so they are easier to see.
    • Move them to the side when loading media, otherwise they will always be in the way.
  • The printer is very dark and closed (they do not want the UV light to escape/reflect. As a result make sure you have a flashlight to easily see inside (when removing/cleaning your media clamps, etc.).
  • The digital display nicely shows the ink level of the 8 ink cartridges/cassettes. However, is does not show the level of the 9th cassette, the cleaning cassette.
    • You will definitely forget to buy a cleaning cassette in time. I expect the printer will not work when this cassette is empty?
  • Printer does not want to print when the drain-bottle is half full.
    • This is up the operator to decide, not the printer, especially when the drain bottle is half!!! full.
  • When you are in the menu you have to manually navigate out of the menu to the main screen or the printer will not print. WTF???
Bugs.
Software (firmware machine and Versawork) is mature. Not a lot of bugs encountered.
  • 1x No ink/cartridges present error, needed to turn the printer off, and printer again needed 10 minutes for maintenance before it was ready.
  • 1x Network error, black screen with white lettering, needed to turn the printer off, and printer again needed 10 minutes for maintenance before it was ready.
  • White not being printed, while it correctly shows in the rip (that it is present).
  • Blade force was set to 50 gr, all was fine. All of a sudden the blade would not cut proper any more (not enough force). Replaced the blade. Still did not work. Increased the force to 100 gr and it cut again the same as it previously did on 50 gr of force.
Conclusion of my Roland LG-640 review.
Problems/limitations have been reported to the Roland dealer and Roland. None have been disputed.
So the printer has a (very) limited usability, only for very small specific niches. I would only recommend using this machine on mat white vinyl (ignoring the cost issue). As it produces a very nice mat print (use RGB black instead of CMYK black in your prints) (yes this will be a big pain in the butt and not really viable).
From an economic and environmental perspective this machine is completely unacceptable. Thus should not be purchased by 99% of sign makers (in my opinion).
Questions? Let me know.
Is this machine similar to the Roland mg64 ?
jlgb
I assume you mean Roland MG-640. From what I understand is the MG-640 the old model with the old heads and the LG-640 the new model with the new heads.
Btw Roland clearly states in its marketing, see below, that the LG should use less ink and create less waste, as also said by the dealer, but it clearly does not. Even according to their own information, I shared previously.
Debunking UV Printing Myths: Separating Fact from Fiction - July 13, 2023 - Ginny Mumm - https://www.rolanddga.com/blog/2023/07/13/uv-mythbusters
BVG
Wow....based on that if we print just over half a roll per week day our annual ink cost would be $61,000.
Cleaning alone with no printing would be $22,000 a year. That's absolutely insane. We've got a unit on order currently, but we'll be having a very frank discussion in the new year with Roland.
jlgb
As regarding print speed. Based on my test of 7 december the LG-640 is about 2.17 as slow compared to our XR-640. It would have taken our XR-640 6 hours to do this work (44m2, 34 meters) the LG-640 took 13 hours. Due to 2 "problems" you will constantly be using overprint (which drops the speed down from 6 to 2.2 meters a hour) and due to the excessive amount of inkt/cleaning/maintenance cycles.
The LG-640 (plus BOFA) consumes less energy (200 + 95 watt) per hour, compared to the XR-640 (450 watt) when printing. However, due to the fact the printer is 2.17 times slower it will actually require more energy for the same amount of work. 13 hours * 295 watt = 2835 watt vs 2700 watt (6 hours * 450 watt).
2,84 kWh vs 2,70 kWh. No progress here during the last 12 years.
josephF
Not to bring back an old thread, but what did you end up doing with the machine.? I have the LG300 and it is absurd as well.
jlgb
I have started a lawsuit against the Dealer, here in the Netherlands. As they do not want to take the machine back, or exchange it for a VG3.
Both Roland and the Dealer have seen multiple CoPeck files and they have never disputed my findings or the level of ink wastage. They have simply been lying to customers about ink usage. And Roland is still lying about this printer.
Roland told me they sold a 115 LG printer in the Benelux. This also seems a lie. As all dealers I have now talked to have all sold just ONE machine each! So they likely have only sold about 10 to 15 machines in the Benelux. (I guess that Roland dealers are not enjoying the sales experience of selling these LG printers.)
Initially the Roland dealer told me they sold 5 (they = tech guy doing the demo), eventually it emerged, and I was told, that the Roland LG-640 they sold us was the first LG machine they sold.
I will likely do a review/tour/walk around of the machine on YouTube. If people have any questions drop it in the comments.
josephF
Wild. They are currently having ink malfunction issues as well according to some dealers I talked to. I like my LG a lot, it does the job and I like the results. I definitely do not like the waste though. I also don't understand the whole, "you have to shake the white ink every day", do people not have weekends anymore? I am in my office every day so I can shake the ink daily, but it just seems absurd to assume no companies will ever shut down their offices for holidays or something. They should have built in an ink agitator or something in that slot.
Reactions: 1 users
All printers with white ink have some type of ink recirculation system for the white ink, but as you state, most of these are not 'end-to-end' recirculation. This means that only a small amount of the ink is being recirculated, and not the entire white ink supply. This requires that the printer operator/ owner manually remember to shake the ink on a daily basis to keep the ink supply from settling.
There are a few printers that feature end-to-end white ink recirculation where the user can literally forget about white ink maintenance when not being used, with no white ink waste for extended periods of time (weeks or even months on end).
josephF
Can you be more specific. What issues are Roland having? Thanks in advance.
I don't know the specifics. Just that ink is on backorder in USA because of some ink malfunction. Of course this is just what a dealer I was talking to said. Not even my dealer I was at a vinyl shop and they mentioned it to me, I think to sell me some inks that they had sitting on the shelf...
josephF
Yea this would be wonderful, I wish that we had this on the Roland machines. I am guessing the feature is too expensive for the market.
No, not at all. The entry level 64-inch roll printer with this capability is less than $18k USD. Ping me for details.
Stormy7
hey, did you end up making the you tube video ?> I'm looking at an lg on friday they are running a demo, Reading the form tho is setting me off...
Cheers from Canada
Alex
josephF
Has anyone ran their LG without white ink? Like the initial setup of double black or something instead of white? Does the machine continue as many ink waste cycles or when it is setup this way does it know that it doesn't need to clean so aggressively since the white is no longer needing to be cycled so so much?
This manual page makes it sound like ink circulation is only required when using white ink? But this is for moving the machine, so I am assuming that if the machine isn't using white ink the circulation might be a lot less?
Stormy7
Hey fellas, what's up from Canada.
Did anyone see the update from Roland
Yesterday, reducing ink waste around 40% for the LG,. To my understanding it was 119 cc a day now it should be 68cc .. compared to the MG and mimaki which I believe to 40cc and 12cc a day.
Cheers
josephF
Cheers
I am testing this now. I have been weighing my ink waste per week so I will know more by next Friday if it is indeed as significant as they say. I surely hope it is.
Reactions: 1 users
jlgb
Well speak of the devil.
I inserted a red cassette and it bend the entire needle (the 6th cassette I replaced in this machine) (I have been swapping 3-4 cassettes a week for about 25 years, never had 1 issue or drop of ink). The printer needed a new needle. This was done by a different Roland dealer. They also brought a new red cassette that did not work. Printer kept complaining about "no ink." So I would say that Roland has quality issues with the production of the cassettes.
We inserted the old cassette back into the machine and it worked again. This was friday. Today/sunday wanted to test the printer (it has the new firmware 2.2 installed) and again red ink everywhere (and this UV ink stays liquid.
Machine has been down for about 3 weeks. Not that we are using it. If not clear, do not go anywhere near this machine.
Our Roland VG3-640 (CMYKLbLmLcOr) that this other dealer installed about 3 weeks ago, has been running perfectly, we now have it running about 2 days a week, which will slowly increase to about 5 days a week. This machine will replace our XR-640 (XR-640 is a 6 meters a hour machine, this VG3-640 about a 4 to 5 meters a hour). The VG3-640 is a bit slower. But much better reds (compared to eco-sol max 3), better CMYK greys (10% K - 90%K etc.,), just a much more beautiful print quality compared to the XR-640.
No. The roland LG-640 is simply not working.
josephF
Well tomorrow is one week of printing about my usual amount since the update. The ink waste is definitely better. I don't have exact numbers because my machine is messing up and I have to run medium cleanings to get the heads to print correctly. Dealer is waiting on parts to fix it. I definitely am happier with the waste now. It feels a LOT better. I did a manual cleaning every day anyways, so nothing changed for me besides the ink consumption dropping. I now do my manual cleaning in the morning before my prints start instead of at the end of my day.
It is nice that you turn on sub power and it no longer takes 6 minutes before you can start printing. Now you turn on sub power and it is ready to go. Needs a quick print prep and off it goes. So the manual cleaning at the start of the day makes more sense to me.
