Smoke_Jaguar
After spending a few long days working on the scrapped UJF6042 I got a while back, I am still having issues getting any ink from the heads. I've flushed the lines with ethyl acetate (LF-200's primary chemical), replaced the dampers, flushed the heads directly and gotten great nozzle flow on what appears to be all channels (waterfall check) and gotten all error codes cleared. All caps engage the heads properly, the suction nozzle has been replaced and I have the bed as high as it can go without tripping the work high alarm (since I know even a few extra mm can lead to a nozzle check looking like a puff of color). I know there is a deflate process, but all checking seems to indicate there is no air left in the lines.
The printer was left sitting with LH-100 (CMYK Primer Primer WW) for a couple of years, but was in working shape when shut down. Not sure if there is massive degradation of lines. The ink I got out was pretty bloody thick and I know the cartridge needles are replaceable. Is this possibly a flow issue? Heads seem to be talking to their control board as I used a Ricoh Gen4 head simulator to pass error codes on to the slider board, and it triggered proper errors on the display. I am using new (cheap knockoff) inks, and am stumped. Not sure if there is a case that can cause all 4 heads (8 channels) to die. But I would love to get this unit up and running for more crazy ink experiments.
