Hello to all my printer friends I have a issue here that I cant solve.. here it goes hopefully I can explain this good...
When I set up the printer and the cutting tool goes out to size the media, usually once it is on the way back to right it throws the "motor error please turn power off" But there is no code number thats all it says. Once and while it will go and size the media, then I can do a test print, it will be printing then throw the code, once that happens the printer carrige goes zipping to the right.. This machine has 87 print hours on it and 1 hour cutting very low use..
I have tried the following.. Cleaned the linerar bearings, checked the tension on the cable, made sure that the screw attached to the cable is tight no slipping.... I need help bad here I have jobs that need to be done
Thanks everyone
Thanks everyone
