SIGNTIME
XJ540 ... While in mid print today the printer stopped, beeped, and said "service call 0110" (Input value from Linear Encoder is not changed when the Linear Encoder is setting its origin. When Motor stops during printing, expected movement is not completed on some head.). None of the buttons worked except the sub power. Turn off the both sub and main and turned back on and the code popped back up. Shut off the machine again cleaned the encoder stripe and fired it back up, same code.
What else can I do to troubleshoot this while I wait for a tech to come look at it (Monday
Do I have to go in service mode and clear the code?
Anything else that I should check?.....
)? Do I have to go in service mode and clear the code?
