Question Roland SG grainy print results. (Help Please)
Brendon007
Hey guys I need some help please. Am using a Roland SG 540 an all my small prints like labels an so on are abit grainy an not sharp.
I did some alignment an all test prints are ok.
Large prints are ok but anything small with details just grainy.
Can someone help me with this issue please?
Zoogee World
Have you played around with different profiles, print speeds and heat settings? What are you currently using and what media?
victor bogdanov
What is your print head height at? i had grainy prints once because forgot to lower heads after printing banner. make sure head is low and the settings in the machine show low head too
Brendon007
I’ve recently bought the printer an didn’t do much playing around with profiles like that but I’ve recently started using the Roland DGA Gloss Calendar profile since am using a gloss vinyl for small stickers and labels.
weyandsign
Assuming you're printing with Versaworks. Try this: Media Type: Generic Vinyl 1, Print Quality: Standard, Mode: 12p, Halftone: Error Diffusion, Color Management: MAX Density U.S., Print Heater: 35, Dryer 48
Also make sure your design file is using CMYK colors and not set to RGB
Also print everything in Versaworks from EPS files. Even if it's already rasterized in your design program, export to EPS then print. If you print a raster image directly in Versaworks the colors will look off.
Jazz
So glad I found this post. I am having the same issues with small text for my customer labels. Using Versawork printing to Roland Tru-vis VG@ 540 Except we are also having grainy print issues when printing solid colour labels in orange-yellow colours. But black blues and reds print perfectly.
Brendon007
I will try this here an see how it goes.
cornholio
The horizontal calibration in the sample images is off. Probably the Bias(head slant) as well. you can see cyan not aligning with black, which is a telltale sign for misalignment.(or misfireing nozzles)
