Roland SOLJET XC-540 PRO III??
designtcd
Hi, I plan to take a Roland XC-540 SOLJET PRO II for $ 300, it went 5 heads one is correct, is there a way for me to take and clean those heads, for a start I would use it as a cutter because my cutter broke, so I would try to clear my head, can you give me some advice? Thanks in advance
White Haus
Not a Newbie
I don't see why you couldn't use it as a cutter only, as long as there are no errors preventing use of the machine.
netsol
you can try finding someone with a print head doctor, but there really is no happy ending to this
there were some people on ebay who you could send your head out to & they would clean the heads for a fee.
they will probably be better than when you sent them out but i would be stunned if any of them were really acceptable
Sean@CedarHouse
Printing Money
You can't really clean the heads. If you do manage to get fluid flow, most likely the electronics of the head are going to go bad.
I would just put money aside and buy one head at a time until you have a set. Then replace them all.
You might want to make sure it's the heads though. If the printer has been sitting for a while with no power, then its most likely the heads, but if not then check the other parts of the capping station etc. replace the caps, do all the stuff.
