Roland SP-300i Print & cut registration
AlanRendition
Can anyone help, I have a problem with my SP300i when printing labels, laminating and cutting the label the cut is out of position across and down the roll to varying amounts.
I can sometime get a perfect 1metre sheet of labels. Next time first line of labels is fine but the further rows get worse.
A company I have used for repairs and service have had one attempt at adjusting but did not solve the problem, the company want to replace encoder strip but the young engineer they sent says it is not that.
Can anyone help or recommend a engineer who covers Chesterfied area in Derbyshre UK
netsol
do you mean row or column?
are you off in the direction the media moves, or the direction the carriage moves.
a case could be made (a doubtful one!) that the encoder is bad, if you were off in the direction the carriage travels
AlanRendition
I agree about the carriage travel but think the registration is out in both directs and not always by the same amount as if the vinyl is moving?
Printed sheets 3 sheets of 110 labels yesterday laminated and printed perfectly. printed 4 of the same file last night left until this morning to laminate then cut them. No use out of register in both direction on 3 out of the 4 sheets 1 OK ?
Any ideas?
I agree it's probably one or both the encoder strip being dirty or damaged and/or worn out pinch rollers.
AlanRendition
i have cleaned pinch rollers but did not solve problem. Company from nearby sheffield coming today o look at the printer today, they think it is either the encoders or pinch rollers.
Thanks for helpful comments.
