Roland SP-540i skips first 5–10 mm of first contour cut only (TEST CUT perfect)
oblazev
Hi everyone,
I'm hoping someone has seen this before because I'm running out of ideas.
I have a Roland VersaCAMM SP-540i with firmware 2.60.
The printer prints perfectly, but I have a very strange contour cutting problem.
Symptom​
The first contour of every job always starts 5–10 mm late.
The carriage moves to the correct starting position, but the blade does not begin cutting immediately.
Instead, it starts cutting approximately 5–10 mm after the contour start, then completes the rest of the contour perfectly.
At the end of the contour it returns exactly to the point where it actually started cutting, leaving the first 5–10 mm uncut.
Every following contour in the same job cuts perfectly.
What I've tested​
  • New original Roland blade holder
  • New 45° Roland blade
  • Blade offset 0.25 mm
  • Cutting force 80 gf
  • Different cutting speeds (30 cm/s and even 5 cm/s)
  • VersaWorks 5.2
  • VersaWorks 7
  • PDF files
  • EPS files
  • Cut Only
  • Print & Cut
  • Simple rectangles
  • Complex contour cuts
  • Rotating artwork 90°, 180° and 270°
The problem always follows the start point of the contour, not the orientation of the object.
Important observations​
  • Internal TEST CUT (square + circle) is absolutely perfect.
  • If I cut two identical objects, only the first one has the problem.
  • The second and every following contour are perfect.
  • The problem is identical in VersaWorks 5 and VersaWorks 7.
  • It happens with both simple rectangles and complex shapes.
Additional information​
I also installed Roland Peck 5.0.2.
  • I can communicate with the printer using its IP address.
  • Restart command works.
  • However, "Get Report" returns "Failed to receive."
My question​
Has anyone ever seen a Roland SP-540i (or SP-300i / VP-540) where only the first Knife Down of every job starts several millimetres late, while every following contour cuts perfectly and TEST CUT is normal?
Could this be related to:
  • Tool carriage
  • Cut solenoid
  • Cut carriage board
  • Ribbon cable
  • Firmware
  • Tool pressure / Cut Down Position adjustment
Any ideas would be greatly appreciated.
Thank you!
  • Agree
Reactions: 1 user
damonCA21
It sounds like the solenoid on the cut carriage could be sticking if the blade isn't lowering at all where it should be starting. I would start with that and see if it is moving freely. If not you need to replace the cut carriage.
I would have said it could be artwork related, but not if its happening on every job
dpmoody
There's a small rubber stopper above the solenoid, this can become sticky over time and cause it to stick over night.
  • Agree
Reactions: 1 user
oblazev
Thank you for the suggestions.
One thing that makes me unsure about the rubber stopper is that the problem is not only after the printer sits overnight.
It happens on every new cut job, even if I send another job only a minute later.
The first contour of every job starts 5–10 mm late, but every following contour in that same job is perfect.
Does that still sound like the rubber stopper or solenoid, or could it point to something else?
oblazev
Thank you for your suggestion.
I cleaned the rubber stopper indicated in the attached photo with isopropyl alcohol because it was slightly sticky. After cleaning, I applied a very small amount of talcum powder with a cotton swab, and it is no longer sticky.
Is this the rubber stopper you were referring to?
I'm going to test the machine now to see if it makes any difference.
  • Agree
Reactions: 1 user
