Hi everyone,
I'm hoping someone has seen this before because I'm running out of ideas.
I have a Roland VersaCAMM SP-540i with firmware 2.60.
The printer prints perfectly, but I have a very strange contour cutting problem.
The first contour of every job always starts 5–10 mm late.
The carriage moves to the correct starting position, but the blade does not begin cutting immediately.
Instead, it starts cutting approximately 5–10 mm after the contour start, then completes the rest of the contour perfectly.
At the end of the contour it returns exactly to the point where it actually started cutting, leaving the first 5–10 mm uncut.
Every following contour in the same job cuts perfectly.
The problem always follows the start point of the contour, not the orientation of the object.
I also installed Roland Peck 5.0.2.
Has anyone ever seen a Roland SP-540i (or SP-300i / VP-540) where only the first Knife Down of every job starts several millimetres late, while every following contour cuts perfectly and TEST CUT is normal?
Could this be related to:
Any ideas would be greatly appreciated.
Thank you!
Symptom
What I've tested
- New original Roland blade holder
- New 45° Roland blade
- Blade offset 0.25 mm
- Cutting force 80 gf
- Different cutting speeds (30 cm/s and even 5 cm/s)
- VersaWorks 5.2
- VersaWorks 7
- PDF files
- EPS files
- Cut Only
- Print & Cut
- Simple rectangles
- Complex contour cuts
- Rotating artwork 90°, 180° and 270°
Important observations
- Internal TEST CUT (square + circle) is absolutely perfect.
- If I cut two identical objects, only the first one has the problem.
- The second and every following contour are perfect.
- The problem is identical in VersaWorks 5 and VersaWorks 7.
- It happens with both simple rectangles and complex shapes.
Additional information
- I can communicate with the printer using its IP address.
- Restart command works.
- However, "Get Report" returns "Failed to receive."
My question
- Tool carriage
- Cut solenoid
- Cut carriage board
- Ribbon cable
- Firmware
- Tool pressure / Cut Down Position adjustment
Thank you!
