Roland SP540i error ink cartridge not installed
rcgraphics77
Hello I am having some issues with a Roland SP 540 I where it gives me an error not recognizing the ink cartridge being installed. It doesn’t happen all the time but it does happen periodically. For example, I’ll be Printing a job and in the middle of it it stops and it says air cartridge uninstalled and it’s the yellow or magenta cartridge. It happens only in the yellow and sometimes with magenta. It also happens when machine is asleep, it will wake up beeping with that error. I have swapped cartridges for new ones and still does it. I need any tips that anybody has us to what I can do or what I need in order to fix this machine. Thank you in advance.
As these printers get old, it appears that the cartridge detection sensor starts to fail. You can try taking a long straw and putting it right up the cartridge detection sensor. It is at the back end of the ink cartridge holder, it is a little tiny white square about a millimeter square. If you take a long straw and put it right on top of that and take a can of air at the other end, you can try to blow out the sensor.
the other thing to do that will probably help you is just put a couple pieces of masking tape on to the ink cartridge as in the picture that I have shown here. This just raises the area of the cartridge that contacts the sensor just a little bit and pushes against the sensor better.
yes, all you have to do is walk past the printer and it will start telling you the cartridge is not in there. Or breathe.
  • Agree
Reactions: 1 user
rcgraphics77
Thank you so much!
damonCA21
If that doesn't fix it then replacing the ink dock is the easiest option as you can't get the switches just on their own. I have plenty of replacement docks in stock if you need them
netsol
my #4 cartridge always seemed to know when i was in a hurry to print something & would go intermittent at the damnedest times
  • Agree
Reactions: 1 user
