Roland SP540V prints to dark
krazykoncepts
Hey Guys looking for some help
I have a roland versacamm sp540v and am using versaworks as my rip software. Its doesn't matter what media profile I use everything prints dark. I have even downloaded new icc profiles and have the same problem. Can it be anything with the printer?
Just looking to troubleshoot this before I call in a tech.
CS-SignSupply
Does your nozzle test print CMYK? What media? Print dark on ALL files?
Have you tried changing the different density settings? Max Impact, Sign & Display, etc?
krazykoncepts
i haven't played around with the density settings much since I am very unfamiliar with them.
We have printed gloss sticker stock, canvas, 130z banner and its all dark.
All nozzels are firing, the scan isnt the greatest but see attached
  • nozzle test005.pdf
CS-SignSupply
Test print looks good. Have you run the Roland Color Chart from Versaworks to see if it prints dark?
Some setting is not correct in Versaworks or profile is wrong.
krazykoncepts
printing one out now...so far its looks just like the monitor give or take
why would the printer print the colour charts fine but not when a file is ripped?
CS-SignSupply
What are your files designed in? Embedded profile? other color settings being exported with the file from the design software?
krazykoncepts
print files are normally uploaded as a pdf and print/cut files are generally thrown into illusatrator to make cut contour lines then uploaded as a eps.
As for for embeded profiles or other colour settig being exported with the file, I dont think so. We arent doing anyting different when we design in house but regardless have the same problem with files that are sent to us from customers.
Sounds as if your monitor is way outta whack.
Try looking at the same file on someone else's computer/monitor.
You could very well be looking at a monitor which is so light, you need to design darker visually and this in fact messes with your end result.
krazykoncepts
tried various monitros and we get the same issues, we have even printed the same files through onyx on my agfa anapurna flatbed and its prints perfectly.
