Roland Spot colors- is it possible to print PR 35K?
SIGNTIME
Yes ... the way it is named makes the difference if i remember right someone couldnt get their prints to cut bc they had a space in the name of the cutcontour color.
Tattoosleeve
As long as the layer the color is on is not called "CutContour" then the color should print. I've also had problems with it wanting to print even when the layer was called "CutContour", which I was told tells the printer to ignore the color for printing and to use it for cutting only but I haven't figured out the variable that causes this problem as it seems to be intermittent.
