Dave is good to go if you are connected with him I would trust him. We have done business with him in the form of selling machines but never had him repair anything cause I handle it.
Sign-in-china is a good source also. I would almost attempt to repair the board first if Dave will do it for you cause you want to eliminate the higher cost of popping in a new board and find out you are chasing another demon in the boards somewhere and blow out a new board.
Dave will know what to do with adding you some fuse holders on the Soljet 2 head boards as the Soljet 3's had them from the factory. Just as a heads up you look like you may need some new heads when you get all this sorted out, I mention that cause you might end up being several thousand into this printer if you don't know that already. The printer is worth it especially when you run bulk ink and the savings pays for itself.
