Roland Truevis VG-640 0400 error Help
Joesignshop
I had some ink dropout occurring more and more on my lt cyan/lt magenta printhead test print (only on the lt cyan side), so I decided to change the printhead out. Ive done this many times before. New captop, all lines checked for suction, new damper, it appears all is lined up. When its capped, I put VERY light suction on the captop bottom tube to see if the damper arms move inward and stay in place, until I remove the syringe, so it appears that portion holds a vacuum. I go to a damper fill and it starts but I see no ink coming from the lines and top tubes into the dampers and then get an 0400 error. I decided to put the old printhead back (that worked prior) and do a damper fill and get the same 0400 error. Checked the sensors for the damper arms and they are functioning properly. Put the new head back in and getting same error. What would happen if I did an "ink fill" ? Any help would be greatly appreciated!
What is the secondary code?
dtfonestop
Since the old head throws the same error, I'd stop suspecting the head and look at the path that pulls ink into that damper. On a damper fill the machine is counting on suction from the cap to draw ink down the line, so if the damper never fills, it's usually one of three things: the cap top isn't sealing on that head (worth checking the head is sitting at the right height and the cap lifts all the way), the suction tube under that cap is pinched or swapped with its neighbor after the rebuild, or air is getting in at the damper-to-head joint, often an O-ring that rolled or didn't seat.
The arm now sitting completely off the sensor sounds like that damper went the other way and got pressurized or emptied, so I'd pull it, make sure it isn't collapsed or overfilled, and reseat it before trying again.
I'd hold off on a full ink fill until you know the suction side holds. It burns a lot of ink and won't fix a leak.
Did you have to undo any of the pump tubes to get the new cap top in?
Joesignshop
I can now count out the sensors as I put new ones in and did a sensor check. I can definitely say its not the printhead as its been changed with new and swapped with others 3 times to be sure. I also am positive there is excellent suction at the cap as I swapped pumps and can hold a positive vacuum with a syringe and the dampers arms come in a stay. What happens is as soon as it does a clean both arms swing out to a scary limit, almost like the pumps in the rear are pushing too much ink in the dampers and the sensors arent stopping it but the sensors have all been changed and swapped. Might it have something to do with the rear pumps in the back? I need a tech for sure in Central Florida. Know of any?
dtfonestop
That detail helps a lot. If the arms swing out right after a cleaning, the cleaning itself is fine and it's the refill afterwards that isn't stopping, so I think you're right to look at the supply side rather than the head.
The damper sensor is what tells the supply pump for that color when to stop. Since the sensors are new and test good, I'd check two things before anything else: that each sensor's connector went back to its own channel (if two got crossed during the rebuild, one pump keeps running while it watches the wrong damper), and that the flag on the damper arm actually passes through the sensor when the arm moves in. A damper that's slightly off in its bracket can look right and never trip it. If both check out, a supply pump or valve that's letting ink through when it should be off is the next suspect.
For a tech, Roland's support line can usually tell you who covers Central Florida, and your ink supplier will know who's busy in your area.
Joesignshop
Thank you that's good info. I definitely checked and made sure that the sensor wiring is not crossed. But I always keep in mind that even a new part can be faulty. That being said the sensor check is coming back 100% on all sensors. Like you, I do think its leaning toward the supply pump and/or valve but not sure how to check those at this point. In the meantime, I am letting all the heads soak each day and emptying and replenishing the captops with new cleaning solution daily. I cannot turn it on as it will start the self clean and risk damper blowout. Hoping this wait time + soaking isn't doing any damage! **I will definitely respond to this thread once the culprit is found!**
dtfonestop
Soaking the caps the way you're doing is fine for a while. The thing to avoid is the caps drying out or the solution getting dirty, and you're already on top of both.
For the supply side, you can learn a lot with the power off. Pick the color whose damper over-fills and watch whether ink keeps creeping toward that damper with the machine sitting off, or whether that damper is fuller in the morning than when you shut down. If it is, ink is getting past the pump or valve on its own, and that's your culprit. Compare it against a color that behaves.
Also look at that color's supply tube where it runs through the pump. A tube that's worn flat, cracked, or seated wrong can let ink through when the pump should be holding it back.
If everything holds with the power off, the pump is probably being told to run too long. Then it's more of a board or connector question than a mechanical one.
Hope you find it soon, and thanks for promising to post the fix.
Joesignshop
Ok after 3 days of taking everything apart and testing and cleaning I finally figured it out. When I put the new printhead in I had the ink lines going into the top of the damper crossed!!! I think it confuses the pump boards and throws the errors. When I finally looked at an old test print I was like.. "omg wait a minute, could it be???" sure enough I swapped them and did a powerful clean and voila. What a dope! But now I have a nice shiny "new" printer with just about every part checked and rechecked and calibrated. A wise man once said: Check the dumb stuff first! I swear these printers take years off your life. :banghead:
