Joesignshop
I had some ink dropout occurring more and more on my lt cyan/lt magenta printhead test print (only on the lt cyan side), so I decided to change the printhead out. Ive done this many times before. New captop, all lines checked for suction, new damper, it appears all is lined up. When its capped, I put VERY light suction on the captop bottom tube to see if the damper arms move inward and stay in place, until I remove the syringe, so it appears that portion holds a vacuum. I go to a damper fill and it starts but I see no ink coming from the lines and top tubes into the dampers and then get an 0400 error. I decided to put the old printhead back (that worked prior) and do a damper fill and get the same 0400 error. Checked the sensors for the damper arms and they are functioning properly. Put the new head back in and getting same error. What would happen if I did an "ink fill" ? Any help would be greatly appreciated!
