Roland vp540 surge protector
balstestrat
Problem Solver
How many amps does Roland say it needs? It says it next to the cable on the back. You can base it on that. 1000VA is good for running ~600watts depending on the manufacturer.
Also only you know how long you want the UPS to run so buy one that suits your needs. Does it really help if it runs for 4 minutes?
balstestrat
Problem Solver
You have 230 volts? Then you would need at least 1000W UPS. Which would be at least 2000VA.
But it's up to you for how long you want to run it.
MikePatterson
Head bathroom cleaner.
Your going to need a big UPS and a huge battery to run it any length of time.
Volts X Amps = WATTS
120v X 4.2 amps = 504 watts
solantis
I only need it to power the printer for around 2 hours as our electricity tends to go off from time to time for 2 hours only.
But I intend leaving it connected to the printer the entire day
balstestrat
Problem Solver
Would it be printing during that time or not?
Without printing during that time on standby/sleeping you can probably get on with a 2000VA unit.
If you print... Well just don't. Buy a diesel generator if you have to print while black out.
solantis
So if a 1000VA unit can push 600w and the printer requires 504 watts why wouldnt it work?
I've already bought the unit so I need to make it work. I merely need it to avoid the printer going off when the electricity goes down and not for printing but that would mean that I needs to be connected 24/7
balstestrat
Problem Solver
Because you didn't answer me if you have 230V and with that 4.2A = ~960W :mad:
If you have 120V in South Africa and the 4.2A was for that voltage, then yeah 1000VA is fine.
signage
for a short period of time being 230V!
Like said above if you are looking to be using this printer with power outages you should get a backup Generator and a UPS to supply power while the generator is starting up.
please, don't do this
this is a topic where i have all too much experience
unless you want to spend upwards of $1500 on a good, online dual conversion ups, you will do more damage than good. i plugged one of my older rolsnds intoa GOOD heavy duty rack mounted APC backup. the sounds from the roland power supply scared the s**t out of me.
i posted a picture of the type of surge protector you should purchase, the kind the copier people use. these are what i protect all my pronter plotters and color lasers with. ricoh WILL NOT cover one of their machines with a service plan unless it is plugged into one ofv these (ricoh could care less about your investment, but they DAMN SURE want to protect their own)
if i can do some video capture of the difference between good clean ac line voltage, ups generated ac voltage, and what the transition looks like whrn the ups "switches over" i will. then everyone will understand why this is NOT a good idea.
like this...
