I am seeing more of these fail now due to the age of the machines. If you have a decent electronics repair place near you they would be able to test the supplyOk, thanks. I will do a little trouble shooting on it. Power supply makes sense given the age of the machine.
I don't. Today the light was on solid but the machine showed offline. I was able to restart with the switch in the back. When it is dark on the button I have to unplug and replug itI am seeing more of these fail now due to the age of the machines. If you have a decent electronics repair place near you they would be able to test the supply
That is why we changed the plug and cord as they were both original. When the service tech comes back our I will have him check all of that. Right now we are not even getting power. No lights or anything with the switch on.If it is turning off when being bumped that would point to a bad connection on a cable so that is worth checking too
If I can't get it working then I won't replace it. I have a cutter now and will use it for whatever comes up for cut work and just source any printed work.It’s a VS, not a very proud Roland printer.
it has been deemed end of service, end of life, end of support, end of parts, get a new printer
