Roland VS-640 Printhead Test Caused Burn Smell – Now No Output
Valerio9090
Hello everyone,
I have a problem with my VS-640. I removed the current printhead to install another one in order to test if it was working or defective.
After installing it, I powered on the machine and got the error message: Temperature too high – 40°C. I then noticed a burning smell right away. I shut everything off, waited 10 minutes, removed the head, and reinstalled the old printhead.
When I powered it back on, the machine started up normally without any error messages.
However, when I tried to do a test print, nothing came out anymore…
Did I blow a fuse on the mainboard or on the carriage board?
Thanks best regards Gabriel
Jim Hancock
Old School Technician
You need to check the fuses, output transistors and replace the burned cable, to start. And toss the old head that caused this...
Valerio9090
The head cables (flat cables) look fine. No discoloration visible.
The defective head is in the trash.
I’ll check and measure the fuses later.
Do you happen to know which ones it could be right away?
Thanks and best regards.
damonCA21
I would really suggest getting a tech out to look at the printer. A burning smell with the new head means you could also have damaged that, but you need to find out why you smelled burning. There could be a power surge from somewhere else in the printer, and heads are too expensive to damage new ones.
