Clean the heads with lint-free
swabs and clear cleaning solution from Roland.
Clean the Encoder Strip.
Make sure head height is on low or the correct height. If head is too high you can get over spray.
Honestly you are probably looking at needing 1-2 print heads. Order them off
sign-in-china and have the dealer install them. Don't worry about the "you won't get a warranty" chatter via this forum or the dealer, that printer is out of warranty. While you are at it....grab new cap tops, 3 pumps, 14 Ving dampers (You only need 12 but its good to have extra). If you are going to be working with this machine for awhile....I would get a encoder strip and extra encoder strip reader. These parts are pennies compared to the dealer vs
sign-in-china. Select DHL and they arrive in 3 days. Then you will know where the machine is mechanically and if you pay attention to the tech when he is there you can learn how to fix it yourself moving forward.
