Router Bit Suggestions
Think713
Like, how are you cutting these? Just trimming the edges down to exactly 4'x8', or a bunch of 1" circles?
I can't count the sheets of aluminum and acm I get out of one belin bit. Somewhere between 20 and 80 if I had to guess, but I don't have any way to gauge that honestly.
We usually are just cutting blank rectangle shapes. We are doing 24x36's often. And we bounce around from 3mil and 6mil thickness material. Sometimes we route on .5" PVC
Edit* We also do quite a bit of faces for pylon signs, so acrylic and polycarb... but we typically swap the bit for the acrylic and polycarb.
JBurton
Signtologist
Is that for ACM or just your plastics as a whole?
Sorry, no, just ACM. Plastics like lexan, 3/16 thick, will get stepped through at 90 ipm, .125 first pass, with a .125 bit, 18700 rpm. Acrylics are usually for a push through sign, hogged out with a 1/4" bit, so it's between 60 and 90 ipm depending if it's a finished edge, 18700 rpm still.
Perhaps you are burning up your bits by running them too slow? Chipload directly correlates to heat removed from the system, too much heat and the bit will snap. I've never had problems cutting acm at 60ipm and 18700 rpm, I'll do it for more detailed copy cut out of a panel.
Do you have any ability to reduce the acceleration of the machine? I find most manufacturers prefer to push the motors to the max, and don't even include options for reducing the acceleration. Reducing my acceleration to 10% shows no real reduction in speed, instead of a 120" cut taking 2 minutes at 60ipm, it will take 2 minutes and 5 seconds. Too much acceleration puts lots of load on the bit all at once, causing deflection, potentially causing broke bits.
Think713
Our bits arent snapping, theyre chipping.
Think713
And yes we have full control over the speeds and feed rate... Its all inside the colex software.. but the settings are default for the material that is input into the system. We dont do any pushthru stuff... Mostly just faces for signage, nothing too indepth. And our acrylic and plastics default at 24000 rpm and 70ipm
I think its just cheaper bits and we need to try something a bit better.
JBurton
Signtologist
Speed is your spindle rotation, feed is your top speed, but acceleration is how quickly you go from standing still to full tilt.
And then yeah, as you say they are chipping, I think you're right pointing to cheap bits. That aluminum skin on acm should not compete with the bit in terms of hardness.
Think713
i woulnt say it competes... what ends up happening is the top layer starts to fray and then i have to shave off all the edges which is annoying and time consuming.
packratsigns
Make sure your material is held down firmly.
Clamps ,glue, screws or vac hold down.
Vibration and chatter causes issues.
People have found cheaper bits that work for their setups.
The companies I work for can afford the Belin .
Also heard Onsrud bought them out ?
Think713
The vaccum for the machine does pretty good holding down the material. Any excess clamping beyond some edge holding is going to interfere with the carriage...
I found a few different bits from the brand suggestions above, and we are going to try them and just see what works for us.
bowtievega
Sounds like your bits are just getting dull not chipping which is probably due to quality of bits. The speeds you are running should be fine. You really shouldn't have bits breaking cutting ACM so that is probably down to the quality of the bit as well. We swap out bits out when the edge quality starts to drop and visually leaves a mark around the piece or fuzzy edges. The bit will still cut just fine but you can eat up waaaay more time cleaning edges of parts instead of just swapping out bits. The aluminum skins aren't much but it does dull the bit faster than you think since we don't run cutting fluid on ACM.
Think713
Theyre chipping. The very tip will break off (probably a milimeter worth) and the initial face of the inside of the start of the bit shears off. I wouldnt say theyre snapping. They still will absolutely cut, but as youre mentioning the edges are so bad its not even worth dealing with. The time for finishing is excessive at this point. We also do not run any fluid because this router just doesnt have that feature.
JBurton
Signtologist
Oh man, if that happens, the bit is worthless. Any chance these bits are getting mishandled when not in the machine? I've dropped a bit when going to load it, and didn't noticed that tip had come off, and proceeded to troubleshoot everything else, because the bit couldn't be the problem, it was 'brand new'.
Have you tried any of the suggested bits just yet? It's like waiting for a show to drop on hulu, but I'm spoiled by binge drops...
bowtievega
Ya i agree that would absolutely be a crappy bit. The only time we ever have actual chips in the cutting edge is when someone drops it like JBurton suggested or someone screws up and plunges into aluminum super fast.
