RCC take from flexisign they're the same but flexi mybe not have enough ICC
in both there're command from print setting called (color mode ) you can choose CMYKLmLc or CMYK but again check your cap .
The capping station was brand new when I received this printer, the sponges were clean white and all the drain lines on it were clear. There is ink ejecting through both ink drain lines from the bottom of the capping station out into the drain bottle. Can you please detail what else you recommend in way of adjusting the capping station,
After sitting in the ink dampened sponges for several hours, and a few powerful cleans I started getting a bit out of the light magenta jets, and even a few (I know *FEW*) bits of lines from the magenta nozzles. (see print test below).
I am having a bit of difficulty keeping the ink lines primed. I remove the damper, draw fully out of the lines with my syringe, in the short few seconds it takes to reconnect the line back to the damper the ink seems to "suck" back up the ink line leaving 3-4 inches of the line right above the damper inkless. It appears that the ink sometimes continues to recede even after the damper is connected and snapped back into place. The little line nuts and o-rings are all present and appear to be in good shape. I have also drawn the ink through the damper with the ink line connected, the dampers are about 1/2 full at the moment and if I were to attempt to keep drawing ink through them with the syringe, they will become completely full.. Is this a problem having the dampers completely full? Any Ideas why the ink keeps losing prime and receding back up the lines?
I am going to get some cleaning solvent and look for new dampers this afternoon.
thanks again all... I am making steady progress bringing this old girl back to life.
Test print:
