Semi Trailer Price Check
Waabz350z
What would you price for something like this? I came up with $1829 for both sides. The picture posted is of an existing trailer (with paint). I will be duplicating the lettering on a new trailer. Using 751
Square Logo 5’-0” x 5’-0”
Lakeshore 22’-0” x 2’-8”
Display Co. Inc. 22’-0” x 1’-4”
Sheboygan, WI 9’-6” x 1’-0”
Thank you for your help in advance. :thumb:
theroq
With the measurements you gave I came up with this.
@ $8.75 sq. ft. it would come out to be around $2292.50
(If he was a good customer and possibility of repeat business
@$9.75 sq. ft. it would be around $2554.00 This is still a decent prices, factoring in you'll probably have to rent or us a scaffold
iSign
I'd probably want $2500 minimum.
Years ago I could see myself taking on a job like that for under $2K, & with cut vinyl.... the material cost is cheap, so it's more about how fast you work, & what your time is worth.
These days I have more jobs that many of my competitors can't do... so on the jobs they could do, I'm less worried about bidding competitively because I don't mind as much if I get it... & my rates are higher on stuff the competition can't do, so I don't want to pull myself off that work to do this work at a lower rate.
So if you think you can be happy with $1829..
or if you bid $2K would you be bummed if your competition got it for $1800? If so... go with $1829
Checkers
A quick price would be about $2500 for 2 sides. Add more if you want the back and front done.
Retail for 3M vinyl would be about $1300 and the rest would be travel and installation. This assumes that the new trucks are clean and there isn't large number of rivets. Installation would be on-site and in a climate controlled building. Add 30% if it was to be installed outside in the elements.
Checkers
