Just In Sheet Yield Nesting/Imposition Calculator
FireSprint.com
Trade Only Screen & Digital Sign Printing
Hi Guys,
Set this up today for you to use freely. It's a sheet yield nesting/imposition calculator for rectangles (or squares). It will tell you have many of a smaller sized rectangle will fit in a larger one.
Not that hard to run through the possible scenarios with a notepad and a calculator, but this will save you some time.
Create a shortcut link on your phone's desktop for quick access!
https://www.firesprint.com/sheet-yield-calculator.html
myront
CorelDRAW is best
I prefer width and height. a 4 x 8 sheet of coro would be 4'h x 8'w (landscape) or 4'w x 8'h (portrait) Have to make it dummy proof. is 3/4/200 March 4, 200 or April 3, 2000? That's why the military writes it as "3 Mar 2000" no confusion, no margin for error
Just me I guess
FireSprint.com
Just me I guess
You're just referring to the labels? So you would make it Width & Height instead of Width & Length?
GB2
Old Member
The standard should be Width (horizontal left to right) x Height (vertical top to bottom). The horizontal measurement should come first followed by the vertical measurement.
FireSprint.com
So when buying plastics, the second number indicates the length of the grain from the manufacturer.
Also, what do you call the dimensions of a roll? Generally we say length. Working on a roll length calc as well, so this can borrow the formulas.
All that being said, y'all are right. I have made the correction. Thanks for the input. Hope you find this tool handy. What other calculators do you think could be useful?
FireSprint.com
What other calcs could be helpful? Would love to build more!
A few ideas I have:
- Roll Length Calc (based on quantity of a print)
- Shop hourly rate calculator
- Sign equipment loan calculator with ROI
- Pantone to CMYK/HEX/RGB conversion
ikarasu
Cmyk to pantone would be handy. Illustrator is a bit finicky with that.
For the above...adding custom spacing would be nice. IE. .25" spacing for a router bit, or 1/16 for a saw blade, etc.
graphicsottawa
a.k.a. Phaedra
I'm on the Width and Height bandwagon as well. Whenever I'm setting up a spreadsheet I do it in that order because that's the way it's set up in Illustrator. Less translation of terminology ==> Less stupid human involvment ==> Less chance for error.
FireSprint.com
This is done, go check it out!
Kemik
I sell stickers and sticker accessories.
You could add a label gap to this calc, for space between die cut labels, 3" x 3" square plus a 1/8" gap before the next 3" x 3" square, or Eyemark/Crop gaps as Mimaki can have crops around every individual label or a group of labels.
StephenOrange
Eater of cake. Maker of .
Oh no, this is all in weird American playtime-for-kids inches and feet. Maybe make one for the grown-ups around the world that use Metric ?
Yes, I’m only kidding about your ridiculous measuring ways.
FireSprint.com
Haha. Yeah, it would be kind of nice if we used the global standard.
However, the calc is in metric (or whatever units you want it to be in)!
