Should I laminate or mount first?
JPR-5690
This might be a stupid question but we do very little laminating so I don't have any experience to go off of, really.
Does it make a difference to laminate a print before or after it's mounted to a substrate?
If it makes a difference, this particular job is for small-ish dry-erase charts so I'm applying a dry erase lam to a vinyl print then mounting that to a display board.
laminating first can also eliminate scuffs/scratches in your print prior to & during application
...honestly, i see no benefit to lamination after application unless you're trying to do something quirky like sealing multiple hand-placed graphics under a single clear-layer like pictures/postcards under an epoxy bartop coating.
