Sign Face Rework
craigco
I'd like to get some input from some of you about how much you would charge to do the following sign work.
The part of the sign face I will be working with is 72" x 72" flex face.
The old vinyl is in terible shape and should be the longest and hardest part of the job. It's now in thousands of small pieces. I tested a small part and it will come off, but will take some time.
1. New layout for face
2. Remove old vinyl. Order, cut, prepare and Install New vinyl, Trans, 8500 Series Oracal, 3 Colors
3. Paint trim around the entire face and stripe down the middle, blue in color
4. Add new side panel. .053 White Aluminum 14x73"
5. Tighten up, fix loose sign panels.
6. Add a couple of 9" center reader board tracks with double sided tape
7. Add 7201 as Address in white vinyl, down the stripe on the base of the sign.
I just want to see some figures others may charge for this job.
Thanks,
Craig
signmeup
What's flex face go for where you are? I think it's around $10 a foot up here. $60 for a new face seems like a good idea to me.
Adrian
GVP
I would definitely look at new flex faces - the time and effort trying to remove the old vinyl really isn't worth it. Also, if the vinyl has deteriorated that bad, chances are the flex material might also be on it's way out...
Sign_Boy
I'd go for new faces as well you don't want to deal with all of that.
Not to mention it will last longer and look nicer.
JMO
craigco
Yea the faces are a mess, but they are wanting something to get by for the time being. They are building a new church and plan on getting a new sign sometime in the future. 5-6 years.
So what would you charge for new flex faces with reader board and new design and the rest.
And I still would like to know what you would charge for the work I described. If you have an idea, I would like to hear it.
high impact
Sorry, no cheap fix on this one. I'd charge more for reface then to build a new face. I don't know if you'll get many people to throw out accurate prices on this job.
Acrylic or poly-carb would go for $17-18 per square for just the lettered faces. The track is cheap and can glued on.
I work with churches all the time and 5-6 years is a long time of use for an old sign. Figure your material for a complete refurbish and add 50% margin, figure your time needed for labor, add a few hours cushion at your normal labor rate and pitch 'em the estimate. If you want to donate some then give them a donation check after the job is completed.
Craig Sjoquist
I'd spend a 1/2 hour maybe 1 hour just to see how long knowing I've got the job bill for clean up ...the rest normal charges $12 sq ft for signage
and any maintenace costs
although I'd be thrown out the door for trying to charge that much, lol thinks it's worth more but
font crazy
Sign_Boy
I work with churches all the time and 5-6 years is a long time of use for an old sign. Figure your material for a complete refurbish and add 50% margin, figure your time needed for labor, add a few hours at your labor rate and pitch the repair. If you want to donate some then give them a donation check after the job is completed.
I'm with him on this. It's going to be many hours of labor working on this. You could give an estimated time for labor to cover yourself.
Say between x - z hours at X$.
WhiskeyDreamer
Professional Snow Ninja
i personally have never worked with flex faces, but if they're only looking to get another 5-6 years out of the sign, would it not be more cost effective to create a wrap banner, that would go up one side, over the top and down the other side, then use the grommets to string it tight to the sign?? then give them a price for the new sign when they're getting ready to start rebuilding...
