sign price
petepaz
since everyone is sharing info and pricing
i'm in
i have a job: 4 signs (job signs), .050" alum., 4'x6', 3 color cut vinyl letters (company name and info nothing fancy)
i have been using estimate software and i am coming up with $185.00 each
the alum. is from n. glantz $68.73 4'x8'
Jillbeans
I never heard of .50 aluminum, but anyway, here's what I would charge:
$400 each minimum.
3 rolls HP Vynull @ $40 each, transfer tape log $30, the aluminum at $70, plus your design time, cutting/weeding/masking/application.
Even if you double your materials costs that adds up to $440...
I might use Oracal 651 Intermediate if these are job site signs, as the thicker vynull may last longer.
I think you are coming in wayyy to cheap.
I'd tell the customer I usually charge $450 each but since he's buying 4 he can have 'em for $425 each.
Love.....Jill
petepaz
thanks
this software pricing program is not that great
i am coming to find out that alot of my pricing is low, we are still making money but apparently we could be making more
and i would also use the 651, i really like that stuff real good for the price
Checkers
Hiya Pete,
The program is fine, I use it daily. Perhaps there's a loose nut behind the controls? :)
You need to take the time to configure it to your shops needs. It took me nearly a week to get everything adjusted to where I can now quote and be comfortable with just about any sign, screen printing, or digital printing job that comes my way.
I may not get all of the jobs I quote, but I know that the jobs I do get are profitable.
Checkers
petepaz
it is good with some thing and some stuff it is either too high or too low
like for instance this job
i put in the material price and it figures my hourly labor rate and it priced these 4 signs at $185.00 and i have had it price some cut vinyl graphics out of the water and i have to adjust them lower
and i am sure the nut behind the controls is loose or perhaps his shell is cracked
thanks for the help
mbarden
I'd be at $235 each using Intermediate vynull. Am I missing something? Why such a big differnce between my pricing and Jill Beans?
Hey Checkers what do you come up with in your Estimate. I'm begining to think I need to adjust my labor rate.
Mike B
Big River Sign Co.
Checkers
I'm not going to tell you what I would charge because it doesn't teach you to properly use or trust the software to do it's job :)
What I will add is, even though I am home based, EstiMate tells me that my hourly rate needs to be more than $50 an hour to meet my profitibility goals and I'll have about 11.25 hours invested into the job.
Also, I don't "apply quantity discounts" for less than 10 signs, and I quoted material using 0.063" aluminum and HP vinyl, with 50% coverage per color.
If you want to know more, call me :)
Checkers
petepaz
i wish i could get $400.00, i don't think that will fly
i was going to go tolike $250-275.00 but if you are getting $235.00 maybe i should be aroung there the alum sheets will cost me $68.00 each i figure about $20.00 each for vinyl oracla 651 (again four signs 4' x 6') and i figure about 2-3 hours for labor to cut, weed and apply the vinyl to the alum
i guess it depends on your location
i also have to compete with sign express and signarma both within the same town
Checkers
Hey Pete,
The only time your price won't fly is when your customer says no.
I find it a lot easier to spend 5 minutes to bang out a quote and bet back to work, versus struggling for hours estimating the old fashioned way, only to get the same answer. Simply put, you'll win some and you'll loose some.
Being a former Joisey boy, I'm somewhat familiar with the area where you're located and I know that it's not a cheap place to live. If anything, your prices should be higher than mine or what the others have told you.
The only disadvantages I see are that you have to compete with the Pennsylvania shops. Our sales tax is only 6% as compared to your 7%. Plus the cost of insurance is somewhat cheaper here. Beyond that, everything else within the region is just about the same.
Anyway, the competition doesn't pay your bills or carry the same overhead as you. So, figure out what you need to charge to make a profit and quote the price.
If you want help setting up EstiMate correctly, feel free to give me a call.
Checkers
imaSIGNr
I'm guessing you're talking .o40 alum. ...Using intermediate vinyl @ $12.50 sq. ft. =$300 ea...If he's getting 4 maybe knock off 10% = $1080. They pick up and install.
No graphics, text only, one sided.
threeputt
About $325-350.00 each after discounting for multiples of the same sign.
Side note, but .040, or even .063 aluminum is too thin for the way these guys will probably use these signs. I would use DiBond 3mm. It's more rigid, no rust, no rot material, readily available, precoated for paint, vinyl or digital, drive a nail through it, treat it like wood, less weight, holds up very well. We use it for nearly everything that goes outside and is meant to be fairly permanent. End of commercial.
onesource
Do not be afraid to put a good price out there especially if your willing to stand behind your work!. 300-400 would not be out of bounds and you can deliver it if you want. I get 400-450 for a 4x8 delivered or installed. A 4x6 should not be far off. I only offer the install if it is easy and won't be to far out of the way. If I have to use my cranes to put it up well great! they come with an hourly rate.
I will agree with threeputt
Price and go on!
3dsignco
Pete,
Once you get Estimate set up it really is a good program. It took me months to trust it after quoting for 11 years with a pencil and calculator. It will quote a good 50% to 60% of all our signs so I have no problem letting the help quote all our standard signs leaving me the time to work on the larger quotes that Estimate Can't handle.
A .040 4x6 with 3 colors oracal 651 would be 403.58 and with 3m it would be $463.
Best of Luck to you. But do yourself a favor and work with Estimate to get your prices up to a Profitable level.. Really sounds like you don't have your Overhead Worksheet filled out honestly.
mbarden
Hey Checkers,
Thank you for helping people think about their pricing structure and pricing to be profitable. It is often times a lot easier to spit out a quick answer that people would like to "copy". But that often does nto get them the real answer.
Mike B
Big River Sign Co.
Checkers
Hiya Mike,
Somtimes I feel as if I'm just spinning my wheels. But, I'm glad someone is paying attention :)
Thanks,
Checkers
petepaz
thanks for all the advice
sounds like i have to fine tune my estimate software
(checkers you may get that phone call)
i ended up getting 250.00 each which doubled my material and labor
also there is potential to letter the company trucks
and the .050 alum was new to me also and the signs are just going to be put on the job site trailers all i have to do is make the signs they will pick up and install
