Hi everyone,
I wanted to share a simple walkthrough of how I use SignageStudio 2.0 to prepare signage layouts and place LED modules along guide paths.
For this example, I'm working with an APOLLO sign, using face-lit lettering for “APOLLO”
Inspect the imported artwork and remove any unnecessary objects or paths before proceeding. A clean SVG makes the rest of the workflow much easier.
Keep Keep aspect ratio enabled so the design maintains its original proportions when resizing.
Select a guide path and use Draw or extend a line to correct incomplete sections or extend an existing path. You can also edit nodes directly.
Once everything looks correct, you're ready for module placement.
You can use a predefined module size or create a custom setup by specifying the module length, width and spacing.
Click Place modules to automatically position the modules along the selected guide paths.
After placement, you can select individual modules to add or remove modules, adjust their positions, rotate them, or fine-tune the spacing.
You can also continue editing the guide paths and update the module arrangement when needed.
I hope this helps anyone getting started with SignageStudio.
I’d love to hear from you! If you run into any issues or have ideas for additional features, please let me know. I’d be happy to extend support and make SignageStudio more useful and easier for everyone to work with.❤️
1. Import and clean your artwork
Start by importing your vector PDF. SignageStudio converts it into editable paths.Inspect the imported artwork and remove any unnecessary objects or paths before proceeding. A clean SVG makes the rest of the workflow much easier.
2. Set the sign dimensions
Select all the artwork using Ctrl + A and enter the required width and height.Keep Keep aspect ratio enabled so the design maintains its original proportions when resizing.
3. Choose the lighting type
Select the lettering and choose the appropriate guide-path option:- Face-lit: LEDs follow the centre of the letter strokes.
- Halo-lit: Guide paths are positioned inward from the letter edges.
4. Generate and correct guide paths
Click Create center lines for face-lit lettering. Inspect the generated paths carefully, as some letter shapes may need manual correction.Select a guide path and use Draw or extend a line to correct incomplete sections or extend an existing path. You can also edit nodes directly.
5. Configure and place LED modules
Select the lettering with completed guide paths. In the properties panel, configure your LED module dimensions.You can use a predefined module size or create a custom setup by specifying the module length, width and spacing.
Final workflow
Import PDF → Clean artwork → Set sign size → Choose lighting type → Generate guide paths → Correct paths → Configure modules → Place and fine-tune.I hope this helps anyone getting started with SignageStudio.
