As Geary pionted out they are guides based on national averages. Your price should be higher or lower, based on your market conditions - fixed costs, overhead, profit, etc. So, you really need to figure out what you should be charging for your time and effort.
I haven't used the Signwriter's Guide for years. But, in the years before affordable computerized estimating software, it did make life a lot easier when it came to quoting. Just be sure you're using the right guide for the job though. They have several.
I now use EstiMate Software, available at
www.pricingmadeeasy.com and QuickBooks Pro. I established my hourly rate using ProfitWatch, It's a free program that is also available from EstiMate.
I'm a home based business with very little overhead. After using ProfitWatch and several other methods of calculating my hourly rate, I determined that I need to be billing at least $83 per hour for my time to be profitable.
Now, the only bad part of using any guides or software is that you end up selling a commodity, just like beans, pork, iron or any other raw material. This may be O.K, when your quoting a no parking
sign or a grand opening banner, but you end up selling your skills and the advertising value of your
sign short.
A well designed, manufactured and placed
sign can be worth thousands, if not tens of thousands of dollars over it's lifetime when you compare it to other forms of advertising.
Some good links for reading
http://www.signs.org - look for the video "
Signs: The Speech of the Street"
http://www.sba.gov/starting/signage/
http://www.signagefoundation.org/
http://www.oaaa.org and
http://www.oaaa.org/filelink.asp?EXT=/outdoor/facts/CPT_TREND.pdf
Checkers
