Since last Versaworks update the print and cut is reversed?!
CSOCSO
Just updated to 6.14.0 version and now If I wanna print and cut the printer first cuts the vinyl and then prints on it?!?!? Really weird. The printer beeps when the cut is done and also beeps when print starts?! I don't think it beeped like this. It makes me look at the printer because I think there is an error or something bad happened.
Not sure if I like it that it cuts first. I mean it's cool because I won't waste ink if for some reason the material skews and something get messed up in a major way but since the printer won't continue to print on it but I think I am more concerned about the ink is penetrating the cut and makes the edges curl and head catching something in the meantime...
Cutting before printing is actually meant to prevent curling. It should be an option you can turn off though. Unfortunately I don't know how.
James Gallant
Graphic Designer
It's in the cutting options menu (cutting controls) up at the very top you, there is a drop down (Operation mode), and you can select print & cut, cut & Print, print only or cut only.
  • Informative
Reactions: 1 users
CSOCSO
Yep. my bad. Never seen that before.
Fantazia
If you think, cut and then print is better (if you don't laminate). This is because the rollers don't press the freshly print media, and there are no marks.
