Sing and Post Install
Hoze
Hi everyone!
I have a question about post material for a sign install.
Location, East PA.
I normally set wood posts with PVC sleeves, but my customer is not sure and is asking if the sign needs metal or aluminum posts instead, and I'm not sure because I’ve never installed one that way.
Is there a real reason to go with metal or aluminum over wood with PVC sleeves (longevity, wind load, looks, etc.)?
How do you set them: concrete footing, direct burial, or a base plate on a slab?
Any gotchas I should know about, like wall thickness, post size for the sign’s weight and wind exposure, or how you attach the sign panel?
Where do you source your posts? Looking for a supplier, local in North NJ or PA or online, that sells square or round aluminum or steel posts, ideally with a powder-coat or paint finish.
Photo is the idea of the sign, print size is 12'x40" on ACM
Thanks in advance, I appreciate any advice!
Stacey K
I like making signs
You might check out 4Ever Products website, I buy all my post/panel signs from them and they have some videos that might help. They sell the plastic and aluminum signs. Might get you in the right direction until someone can comment.
I would hope all the lots would sell before your wood/sleeve fails...often these types of customers are pretty cheap so my bet is in the end, they will opt for wood/sleeve.
  • Agree
Reactions: 1 user
Johnny Best
A wood post is solid whereas the aluminum is hollow, the wood post will last a long time. THe wood will rot where the metal will notbreak down as fast.
  • Agree
Reactions: 1 user
unclebun
Why bother with anything but treated 4x4's for a 4'x10' for sale sign? We paint the posts with opaque white stain to get the look. The posts will far outlast the sign or the need for it (unless it's going to take nearly 20 years to sell the houses)
  • Agree
Reactions: 1 user
GaSouthpaw
Agreed.
And then you have customers who end up leaving the sign up as their "main" sign for that long. I mean, you can't help them being cheap, but it always irritates me...
  • Agree
Reactions: 1 user
Hoze
Agreed.
lol That’s actually their plan for later: to make the sign permanent and add some landscaping around it. That’s why they’re concerned about durability.
unclebun
If it's meant to become a permanent sign, design it that way and charge accordingly, and price the conversion from a for sale sign to a subdivision entrance sign.
Aluminum posts can be set in concrete. Steel posts are often bolted to a slab via a plate welded on the bottom. Any metal company can make them for you.
  • Agree
Reactions: 1 users
