Hi everyone!
I have a question about post material for a sign install.
Location, East PA.
I normally set wood posts with PVC sleeves, but my customer is not sure and is asking if the sign needs metal or aluminum posts instead, and I'm not sure because I’ve never installed one that way.
Is there a real reason to go with metal or aluminum over wood with PVC sleeves (longevity, wind load, looks, etc.)?
How do you set them: concrete footing, direct burial, or a base plate on a slab?
Any gotchas I should know about, like wall thickness, post size for the sign’s weight and wind exposure, or how you attach the sign panel?
Where do you source your posts? Looking for a supplier, local in North NJ or PA or online, that sells square or round aluminum or steel posts, ideally with a powder-coat or paint finish.
Photo is the idea of the sign, print size is 12'x40" on ACM
Thanks in advance, I appreciate any advice!
Location, East PA.
