gabagoo
I have used the edge for over 15 years and today I have experienced something weird and different.
I use Signlab to set up my files and then send them as a gad file over to omega and then do all my colour changes and cut info
When I need to cut something I send it over as a magenta or if there is white in the file I will send it also over as magenta so it can be seen.
Today I do that and send it over and when I go to select process colours it never sees the magenta and has turned it back to white. This is very odd to have never had this happen before, so I again went back and looked over the file and re exported. Same thing happened. I then came back and changed all magenta to green and re exported and yes it sees the green.
I disregarded what had happened and thought maybe it was the illustrator file that had some issues and now I send something over again only this time I have set it up in signlab and again it refuses to see magenta.
anyone ever experienced this?
I will add that it is just a magenta that appears in the signlab colour pallette. nothing special about it that I can think of.
very odd
Fred, you out there?
very odd
