Hi,
I have a roland SP-300i from 2009 and I notice that the pump doesn’t run during the auto cleaning cycle (the one when when sub power is off). Actually, every 8 hours the machine wakes up, the heads move a little away from the cap top but nothing more : no ink ejection, no pump activation… I tracked all the wake up in a 24 hours cycle but no pump activation in 24H... It’s problematic because the head and the tube can get clogged more quickly.
Therefore the pump works well. When I launch a cleaning, the pump runs. When I turn on the machine it runs a cleaning cycle as it should.
I don’t know when this problem started but It noticed it few weeks ago.
I have updated the firmware from 2.7 to 2.8 (the last one) but it doesn’t fix the problem.
I have been running marabu DI-LSX inks since 2020. Is there a link with that (something in the firmware that detects it’s aftermarket inks and ruin the printer by not pumping the ink) ?
Any suggestion would be appreciate because I have to launch a cleaning every day to avoid clogging…
