What have you done as far as color management? What is the media that you are you trying to print on?
Before you go crazy and end up hating the machine, you need to sit back and read more about color management. The learning curve is great, but like riding a bike, you do not forget it.
Unfortunately, the only thing that is "plug and play" with these things is the physical installation. The supplied profiles that you will get/find are only valid with certain medias. Just think of copy
paper and its varied brightness. That brightness (the white) will alter colors tremendously.
You will not absorb all color management overnight, so be patient with yourself and the machine. Even so, after you get a handle on color management, you will still find yourself needing and buying additional items such as PMS books and even monitor calibration equipment.
If all else fails, you could always get someone to professionally custom profile your equipment and your media. The only down side is that if you change anything such as media brand, ink, etc, your profiles will be off.
Check out this link. Look for posts by a name of "eye4clr". You will find much info there.
http://printingdigital.net/forums/color-management/
Good luck.
