get a static floor mat.
DO THIS BEFORE YOU ARE ASKING WHERE TO BY A $3000 SYSTEM BOARD
ground the machine as noted above.
GET IN THE HABIT of touching one of the metal uprites of your stand (and probably getting a shock) before you touch the machine.
if you can work that way, buy a static wrist strap. (if the operator stays in front of the printer ALL THE TIME this works out better
OR
Wide Format Printing Defects caused by static. SOLUTIONS: The solution is the StaticElastic™. The StaticElastic™ removes static from flexible and rigid materials before they enter the print head area. A Wide...
stopstatic.com
they solved all my print quality problems with the mutoh hybrid
I AM CURIOUS
this is normally a winter problem, when humidity drops because of hot air heat.
WHY NOW?
