Discussion STS inks. Anyone have experience with them?
greysquirrel
3rd party ink is never a good idea...you are compromising color, consistency, head life, print life, your time troubleshooting...bad bad bad bad bad
Dangreenst
I've got a vendor in our immediate area who wants to earn our business and has been able to match or beat some current prices on our media and inks. They can also match our current prices on non-OEM inks but we're currently using Bordeaux ink and have had good results as they were recommended on this forum by a few people as a good replacement ink at exceptional value. The inks this vendor sells are from a company called STS and I'm wondering if anyone here has tried these inks and whether or not they are a good reliable option.
We're running a Mimaki CJV-150-130 with SS21 inks.
You have one person here with a bad experience with STS Latex ink. Not all 3rd party inks are created equal. Solvent inks UV and Latex inks are very different. You need to have an average of positive or negative reviews to make a reasonable decision. I have been using Boudreaux Eco Solv for more than 10 years with no problem.
Inks
Marabu makes high quality European manufactured 3rd party inks and produce OEM inks for some printer manufacturers as well. Their eco solvent inks are plug and play, chemically compatible and match the color gamut of the OEM products. Not all third party inks are bad. Bordeaux has had their own issues in the past with black inks. Another thing to keep in mind is many of the equipment manufacturers use some of the companies that produce "third part inks to produce their OEM inks.
Someone made a very good point here and that was "if it is not broken and price is reasonable, why fix it". In the end a little loyalty to a good suppler goes a long way. Price or Value?
PhuKing
I DO NOT RECOMMEND
I purchased STS inks for my HP l26500 Latex and it completely destroyed the print heads. I also bought non-oem ink for my DTG that happened to be rebranded STS inks (Asked the vendor for non STS and they lied). It didn't destroy the DTG print heads but the ink was so thin it leaked out of the print heads and was unusable.
A lot of money went down the drain because of STS inks. Stick to OEM inks, they're designed for your printer and give reliable prints. The money you save is not worth the risk of destroying expensive parts like print heads.
Michael-Nola
I print things. It is very exciting.
Bordeaux has some fantastic inks and solutions across the board. Marabu has excellent chemistries. Nazdar is legacy experienced and makes good stuff. INX is OEM and 3rd party supply - don't recommend going 3rd party channel as their sales director/chain will not support end users, STS is also a no for me, I don't like any of their chemistries.
Often 3rd party is not totally plug and play, so you better be into the tech side of the business to handle and make good decisions. If you don't have someone in your company wheelhouse for that, absolutely just buy OEM. Making mistakes here are very easy and will cost you everything.
That said, with some educated tweaking and testing, you can cut ink costs massively down and quality way up. Inks are nowhere close to created equal.
Lastly, rank inks by chemistry complexity - the less complex, the less risky a 3rd party chemistry. Aqueous and Solvents are simplest and longest tested, lots of good ones there. UV Is a highly mixed bag, test carefully and know what you're doing. Latex .... well honestly HP's latex ink is already garbage and hardly holding itself together so I wouldn't dare touch alternative formulas.
Grab a wrench and have fun.
Reactions: 1 users
T Nichols
We have used their ink in Canon IPF 8400s and Pro 4000 without problems. I also use their ink in a small Fuji DX100. Ink works fine, but have: after installing cartridge, have to shut off printer, turn on, turn off and on. Works fine after that. Good sales service, never used technical. If you are close you can pick up pretty quick, or if you order early enough, it usually ships out same day.
Selpkr
I bought a full set for my canon pro printers, one of the cartridges leaked all the inks. I noticed the maintenance cartridge was full. After a month or so one color started clogging and did not print. I tried everything installed new print head, deep cleaning several times. But 2 printers broke down and are beyond repair. So for anyone that is considering, please stick with original.
milchad
"It's always something"
Old thread but here's what happened to our color just be using STS magenta because OKI was out and we had no other option. Same file, and RIP setting. It's garbage. sts.jpg
Smoke_Jaguar
Color shifting when switching ink vendors is totally a thing, can be a real pain. Though, I've had to do profiling for people when OEMs screw stuff up as well. Different pigment loads, particle sizes and all that fun stuff can make a pretty visible difference. Though, if working in a shop where color needs to be accurate, color profiling with a colorimeter should be a routine operation.
