There's always
www.blackle.com
Which is their energy saving page. Its what I use.
The notion that black screens save electricity certainly makes sense when you're talking about cathode-ray tube, or CRT, technology that works by moving an
electron beam back and forth across the back of the screen. "The front screen is covered with red, blue and green phosphors," says Bill Schindler, vice president of
electrical engineering for
Panasonic Plasma Display Laboratory of America. To produce white, the electron beam is directed at the phosphors. However, "when the screen is black, you don't have to fire the beam," he adds.
CRT monitors, which until a few years ago were the predominant models among PC users, consume more power when a
computer screen is white. To confirm this, Schindler measured the energy output of an 18-inch (45.7-centimeter) CRT monitor and found it used 102 watts when the screen was white but only 79 watts when the display was black.
This is not the case, however, with LCD monitors, which have no phosphors and represent the lion's share of every new monitored purchased in the developed world, including those used by laptops. Instead, LCD displays rely on an array of thin-tube
fluorescent bulbs that provide a constant source of light to create a white screen. To make it black, LCDs rely on a diffuser to block this light. As a result, LCDs use more energy than CRTs to display a black screen. Measuring a 17-inch (43-centimeter) LCD monitor, Schindler found that white required 22.6 watts, while black came in a tad higher at 23.2 watts. With a 20-inch (50.8-centimeter) LCD, black required 6 percent more energy than white.
http://www.scientificamerican.com/article.cfm?id=fact-or-fiction-black-is
