(Stupid?) question about white vinyl
Ripcord
I have a roll of 3M Controltac and I'm doing a two color sign in which the green must overlay the white. So the white vinyl has a white backing. With white on white you can't see the decal against the backing to line up the second color.
I ended up solving the problem by doing it on a light table, but wouldn't it make sense to put the white vinyl on a backing of another color so we can see what we're doing?
Is it just me or has anyone else had this problem? 3M no doubt knows what they are doing, so I'm thinking maybe I'm missing something.
rjssigns
Put register dots or squares in the corners of both colors. (unless I don't understand what you're doing...which is entirely possible)
Ripcord
Yes, I've been cutting registration squares. My problem is with the white registration squares against the white backing, I can't see them. Shouldn't the backing for white vinyl be a different color?
Like they said there are other choices which have different color liners.
1. But if you like the 3m why not take a sharpie and color in the reg. squares real quick on the bottom piece of vinyl. Then you can see them. OR
2. Talk to 3M about changing their product. OR
3. Cut your reg marks separate and perf cut all the way through the backer and set it on top of something colored. or
4. Use clear transfer tape.
Ripcord
Thanks, the sharpie is a good idea. I'm going to do that! I still don't understand why the backing is white. I am going to ask someone at 3M...
It's white because 3M makes that vinyl mainly for vehicle graphics and temporary graphics, not for vinyl cutting. The only vinyl cutting it's really meant for is for decal cutting where you have no overlays.
Ripcord
The reason I like it is because it has the air channels to get rid of the bubbles. Is there a sign vinyl that has these channels? (When I use regular vinyl I get so many little bubbles that I can't stand looking at it...)
Mosh
Small cut letters will not stay on using that....You need to use 3M 7125 or Oracal 751. I think the 3M has a clear backing inler.
J Hill Designs
I'd say its time to refine your application technique.
GoodPeopleFlags
I always found it better to layer the vinyl on the substrate it's going on (when possible) instead of on the backing paper first. Say you have green letters with a white outline and they're going on a window. Layering them on the backing paper first and then on the window will usually leave bubbles in the white, around the green letters. And you won't have the problem of the white backing paper.
Ripcord
Thanks, I'm definitely going to try this!
