Substrate for routed mounted sign
J
john1
Guest
Hey guys, I have a customer who wants a custom routed shaped sign. The sign is a flat panel sign just routed to the shape of their logo. There will be a vinyl digital print applied to this sign.
What substrate and thickness would you recommend? The flat wall is stucco and the sign will be about 8' x whatever is proportionate to the height.
I am not installing this, They have a contractor for this.
:thankyou:
J
john1
Guest
dibond....unless you want something thicker
Would 3mm be thick enough? Thickest my supplier has dibond in
Only other substrate they have i can think of is 1/4" alumalite
:thumb:
k.a.s.
3mm DiBond would be fine, 3mm Max Metal would be better since its like 25 bucks cheaper.
Kevin
J
john1
Guest
Thanks guys,
The customer is having someone install this (don't think it's a sign company) but since i don't do installs, They are asking me what brackets and all are needed to install this sign.
Any feedback on what to tell them?
3mm dibond
J Hill Designs
screw it to the wall
if its traditional stucco, plastic anchors will be good enough...if dryvit etc. then they may want molly bolts
2B
make sure to use washers so the pressure is spread out from the screw head to last longer
J
john1
Guest
Thank you guys! 3mm dibond is getting routed tomorrow for it!
