Robert Parkin
Hi there,
I think this might be a common issue but I am unaware of the solution.
I'm running a mutoh Valuejet 1614 with a bulk system installed and one of the subtanks isn't refilling (Black). When I try a little charge it gets stuck at 98%
I've tried using "tank valve check" and one of them doesn't click when prompted. It says valve 1 is off
Could the valve possibly be clogged or faulty?
I've had a technician take a look at it and he said the valves shouldn't be the issue because there isn't any air in the lines below the connections?
Any recommendations would be much appreciated
