Summa D75 - Error in Y axis after it crashed loading vinyl.
SimpleStencils
I am hoping to find help with this here before contacting summa tomorrow... I was loading a sheet of vinyl that went off track and jammed a bit during the feed and caused the ERROR In X axis. I restarted the plotter but now whenever it tries to load, it starts the loading process and then once it get's to the first wheel it stops before feeding vinyl through and gives the ERROR in Y AXIS error. Does anyone have any ideas of things I could try to rectify this?
PHILJOHNSON
Sales Manager
Usually when this happens, the material hits OPOS sensor, knocking it out of position where it makes contact with the pinch roller sensor on bootup and causing the error message you described. You can check and see if the OPOS sensor is loose, but most likely you just need to remove the head cover and resecure the OPOS, and you should be back up and running.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext. 112
[email protected]
